Case would have no where to vent as the pcv valves will be closed. This is why u have the intake valve covers routed to the turn inlet pipe so there is always a suction on the crank case. With an NA the only time the pcv valve would be closed is when there is a back fire or what ever Grimm talked about.
"torque gets you off the line...& hp gets you over the line." - TTKeeper
